Has anything changed with the V-Ray Environmental Fog? I was using it with little hit to my render times, but after the last V-Ray update my render times went from 1+hours to 20+ hours, so I have not been able to use it.
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
bobby give an empty volume grid a go - works pretty good and less fiddly and slow than regular vray fog
just set the rendering type to smoke and up the bottom left graph value to something like 0.05 or 0.01
If you dont want a particular light coming up in the fog then exclude the volume fog from it
even though its very simple and has no settings is there a reason volume grid is faster and works better than vray env fog?
- Likes 1
Which was the previous V-Ray version you are comparing the latest Next Update with?
Have you tested the same scene with the two different versions or this is a general observation?
Please make a test with the previous V-Ray version you are referring to and V-Ray Next Update 1.1 and if the render time with the latest update is longer, please send the scene to support@chaosgroup.com, so we can investigate further.
- Likes 1
Originally posted by squintnic View Postbobby give an empty volume grid a go - works pretty good and less fiddly and slow than regular vray fog
New "toy" to explore !!!(Sorry for my bad english)
Originally posted by Kristina.Georgieva View PostWhich was the previous V-Ray version you are comparing the latest Next Update with?
How do you add an empty grid? I just get the explorer window pop up when i select volume grid. What do I do next?
